- Jun 16, 2009
looking great !! would love to hear them.
where is a good place to get birch ply cut to size then delivered ?
No, I'm going to veneer them, eventuallysuper cabs dev, are you going to varnish them?
Initial impressions are good, to my ears. CPA12s finally have some bassGreat Dev, very nicely put together.
How do they sound?Cooky
Looking good Dev, dump the grills and use spacers for the bolts, the grills fairly sing along.
I think they sounded better in your cabinets, they weren't as bright. With Raggae music, for example, they sound great, but overall some work is needed on the crossover to tame the HF.
If the HF section is 1st order how I remember you can drop a 5-7 ohm resistor in series with the tweeter to drop that HF section a tad.
Rob's your man tho' in this regard.
An L-pad tweak is what's needed to keep the ohms as seen by the amp the same - there will already be one in HF the crossover as the Tannoy horn upper mid / tweeter is much more efficient than the radiator cone.
I have found this calc prog excellent (right at the bottom for the L-Pad stuff).
http://ccs.exl.info/calc_cr.html
2 or 3 dB is subtle but noticeable.
I get the resistors and other component bits from this local place - who have given good service with my custom.
http://www.audio-components.co.uk/
Actually Steve these are the tulip waveguides not the pepperpot CD horns they use the same HF as the 15" and with no resistor in series at all they run hot at + 1.5dB, 1.4 ohm is flat, 2.7 ohm -1.5 db. Even at -1.5 I find them bright.
Hi, They cross @1.5k, 2nd LF, 1st order HF. Mainly intended to be distributed around a venue and/or on top of some subs.
