Originally posted by titian do you hear any difference? (I don't mean the wind that blows outside
Too much rain to go out anywhere so today I had a go at stacking the tuner on top of the CDP.
Cut out an MDF board, the same size as the foot print of the tuner, and lined the entire bottom surface with sound deadening pad, I had left over. This went on top of the CDP.
Removed feet from the tuner, cut discs from Blutack and stuck them back. No screws.
Sliced couple of squash balls and lined the edges with a bead of Blutack and stuck them to the bottom of the feet. Then placed placing the unit on top of the MDF board.
Tried the units with the other one switched on as well as off. Did not notice any change in sound quality. Could have added a layer of copper sheet to the MDF board but not going to bother because no interference was noticed.
BTW. There is a school of thought at TNT Audio who believe that damping the CDP with something heavy on top will improve the sound quality.
The DVD? That is staying under the TV. Hope to make a long co-ax from low loss satellite cable and co-ax connectors from Maplin to connect the sound to the DAC.
Thought it is better to do this rather than get a 10-meter long SCART cable.
