Tenson said:So what do you think of dithering the bit-depth from 16 to say, 24?
Noise shapeing?
Tenson said:No comments on noise shaping though?
3DSonics said:The reason that ASRC's exist is that pro-audio digital recording routinely used 48KHz sample rate (since days long before the CD) and the CD has a sample rate of 44.1KHz. As there is no integer multiple between the two you need to do some fancy DSP to get from one to the other and get there you must, to get a CD from a 48KHz master tape.
dcathro said:I regularly do sample rate conversion from 48k to 44.1 in my Mastering studio and get GREAT results!
But then I do it via a Studer A80 1/2" @ 15ips.
dcathro said:To my ears all asynchonous sample rate conversions suck (including upsampling).
3DSonics said:Consider upping the speed to 30ips (you can get kits to do that) and if you really want to get things going consider using a G36 and get it fully rebuils and serviced.
Yes, unfortunately, digital is just too convenient for most people. I get very few projects coming to me on analogue. However the machines are still extremely useful.Certainly gives the term "Digital to Analogue Converter" another rather different twist and introduces an excellent source of natural and sonically inoffensive dither while we are at it.
Ingenious. Makes one wonder why not go AAD to start with... ;-)
Welcome to the club.
alexs2 said:I've heard the dCS,and liked the results of it's upsampling,and later bought a Perpetual Technologies DAC and Upsampler/Interpolator.
Used together,the PTech units are amazingly good for the price,especially if used with upgraded power supplies rather than the wall-warts they come with.
I now use the upsampler set to 24bit/96kHz with a TAG Av32R DP,with again very good results....the sound via the TAG is smoother and more open than without the upsampler,and certainly less edgy than it can be otherwise.
I think the point of all of these systems is that like with everything else,they work for some people and some systems,and not for others,and particularly so where the upsampling,and/or interpolation of data to 24bit word lengths,isnt done very carefully.
Stereo Mic said:Have you heard the new Integrated? Quite a different experience yet still upsampling (even to DSD)
Markus Sauer said:Have you heard it? What did you think?
