vinyl care
Kab, for the money, great, bit fiddlir than big moth m/c but just as effective on the cleaning front, if you do get hit for duty (i did) it amounts to £23, cost $149+$38 for delivery (£100), okki nokki is next of fully built ones, as has been said, no definitives as to wether a vaccum pump is included, but price is £225, other good thing about KAB is it fits in a shoebox. As for hoover rusting, it has a liquid trap built in, and the connecting hose has a transparent adaptor, if liquid seen in this then switch off and empty it, but due to very little amount of liquid on each record, then you'd need to be doing a seriously long stint to get to that stage.
Got to have a serious play with the KAB over the Bank Holiday weekend.
First I have had a couple of records where the fluid did not get picked up from the suction leaving a very slight residue on the record on the very outer rim. Personally I don't find this important as there is no music there but since someone queried it above I thought I'd just mention it.
However, having cleaned 15 records and then listened to them - yes all of them :D , I can highly recommend this cleaner. If you are thinking of a Knosti then it would be worth saving the extra pennies for the KAB. Being a former knosti user it is considerably better, the improvement from cleaning using suction is by far and away superior to the knosti.
I have the lorricraft which I rate very highly the improvement is immense and removes all the static
