Originally posted by michaelab
I've always found the romantic period to be far the easiest classical to get into and I'd be surprised if people thought otherwise. It's so full of emotion you really don't need to understand it at all whereas Baroque music is well....boring :duck: ....or I just don't get it.
This is a very interesting remark. I'll split the romantic and the baroque music appeal issues.
ROMANTIC MUSIC. It is true that the appeal is quite immediate. There is a lot of passion involved, it is extremely easy to understand it and the impact is often so brutal one wonders how can people not like it ââ'¬â€œ take, as an example, the Scherzo of Bruckner's 8th Symphony: it is just impossible not to be haunted by the main theme. Or the beginning of Strauss' Zaratustra, the beginning of Brahms 1st Symphony, and many others. Even a Schumann lied ââ'¬â€œ of the lyrical kind ââ'¬â€œ is impossible not to move you. If you grow up with romantic music (as I did) it is impossible not to like it.
But, on the other hand, romantic music tends to go on forever and to oppose very different moods. An acquaintance of mine who is hooked on Vivaldi, Corelli, and such music, once told me he didn't like the contrast between the fiery/ heroic and the candid innocence of most romantic music. I understand what he means. Most people brought up on pop/rock sneer on candidness and asexual innocence. And all the pomp leaves them indifference as they are used just to destructive rage. So, in a way, people brought up on rock-pop simply don't get it ââ'¬â€œ romantic music just sounds corny.
There is another factor here: modulation. I don't know much about rock, but it seems to me that it seldom modulates at all. Modulation tends to be confusing to people unused to it and complicated harmonies are simply heard as meaningless.
And, finally, there is the rhythmic factor. Rock-pop are strongly isorhythmic, with very marked strong beats. With romantic music, the phrasing is often so long that there is just breathing and very seldom is there any pounding. Therefore, rockers just loose track.
BAROQUE MUSIC. Well, it is true. A great deal of baroque music is very boring. I like some Vivaldi (the early works) but on the whole, early 18th Century music can be unsuferable. Corelli is very nice as background music, but I wouldn't listen intently to the concerti more than once or twice. But, as it is strongly isorhythmic, has strong beats and shorter phrasing and much less modulation, rockers find it understandable. It has swing, short tunes and simplicity on its side; the emotions are often not corny at all ââ'¬â€œ sheer joy or melancholy. And Biber or Schmeltzer (17r«th century south German) can be listened to in the same mood: marvelous tunes, predictable rhythms and clear harmony.
As a matter of fact one can listen to the Brandenburgs in this way. It is only if you dig further, when counterpoint begins to be clear, that the concerti reveal their true interest. For instance, the 3rd movement of the 4th Concerto is a real fugue. But most people just follow the upper, soprano, line (even musicians: for instance, that is how Goebel plays it). If you do that and have a romantic background, of course it is boring. If you do that and have a pop-rock background, it will be lovely.
Of course not all baroque music is simple, isorhythmic and short phrased. The early 17th Century is quite different: counterpoint still had prominence, harmonies were very complex (in a modal context) and unexpected rhythms were the rule ââ'¬â€œ just think of Frescobaldi and Froberger; and I'll go further ââ'¬â€œ you were intended to play *ignoring* the bars: just think of the French school Préludes non Mesurés which means that only the pitches were notated and the general flow of rhythm just suggested and not actually written down. Modulations do not exist in the romantic sense of the word ââ'¬â€œ the tuning of keyboards prevented it (for musicians: when you have c, c#, d, e flat but NO d flat or d sharp you cannot modulate: music will be horribly out of tune) ââ'¬â€œ but there are all sorts of dissonances. This kind of music if generally not understood either by romantic grounded or pop-rock grounded listeners. The conveyed emotions seem too weird, and one must really learn a new kind of language.
And, finally, the finer points of baroque music ââ'¬â€œ counterpoint ââ'¬â€œ are unintelligible to most people, both romantic and pop grounded. A Bach fugue, when listened 'from the outside' is just a piece of music with many repetitions. But when looked at from the inside, is totally filled with emotion. Now, in a Bach fugue, emotions are just suggested ââ'¬â€œ he uses a kind of minimum element of emotion that one has to learn to decode. When you actually do it, it can literally bring tears to your eyes, spine chills as powerful as the most impressive romantics. I often think Bruckner, great as he was, doesn't say, in pieces lasting for almost two hours, more than Bach does in 6 or 7 minutes.
Bach is the most pure case of emotional abstraction I know. I often compare him to Piet Mondrian, the painter, who was forever in search of the minimum elements of emotional/esthetical meaning. His paintings are rarefied, cold, out of this world. *Not* so with Bach. Emotion *is* present (and emotional contrasts are huge), albeit in a very abstracted way. You just have to get used to the language.
Finally, as a personal note. If I grew up in a romantic setting, how did I become so attached to Bach and all the rest? At my parents home there were many records by romantic and classical masters. I loved them to passion. But I also liked the one record of Bach music in the collection: the 2nd and 5th Brandeburg Concerti, played by Edwin Fisher. I especially liked the 5th. Once, when I was about 12, my eldest brother (there is a difference of about 12 years between us) called my attention to the counterpoint; it was not very clear because sound was very warm (old valves, of course) and not transparent at all. But I was hooked for life.
