brizonbiovizier said:
Not really possible as I need three balanced outputs. Unless I go back to monoblocks just to compare.
You could build a single balanced interconnect (try my CT-100 based recipy - use the centerconductor for pin 1 and add a pair of goldplated silver wires from wires.co.uk for signal hot and cold fed down the air cells in the CT-100) and make a 3-Way breakout at the end (use the cheap all plastic Cliff XLR connectors, they sound best anyway) and you can use a single XLR Output preamp and you get less cable salad on the floor....
Do you have an mfaudio unit?
Yes, I now have a current MF-Audio unit, I do the occasional bit of consulting for them.
Or perhaps I could compare my volco with your tx based unit in your system if the offer for a listen is still open?
You can, the offer is allways open, even to my most bitter on-line "enemies".... ;-)
HAve you tried the S&B step xformer plus active stage plus riaa module approach?
I'm afraid I must admit to being the person who got S&B to start making TX-102 Transformer Volume Controls, the TX-103 MC stepups and both the 600 Ohm and 10K RIAA Modules. In fact, i did a good deal of the design work for the RIAA Modules.
So of course my Phonostage uses TX-103's and EQ-600's.
I use two active stages, first stage is a Siemens E810F high transconductance pentode (gives a gain of around 28db into the 600 Ohm load presented by the RIAA with exceptional linearity and overload margin) and after the RIAA I use a Siemens D3a triode wired for around 2K Output impedance and 32db gain (so overall gain of the RIAA is 40db on the MM input and 66db on the MC Input). The powersupply is a bitr overbuild with a powertransformer from a Mullard 12 Watt Poweramp, 8pcs 10H chokes and 6pcs 120uF Ansar MKP capacitors for +B filtering (plus local RC filtering) and choke filtered heater supply with a 68,000uF final filter capacitor.
Ciao T
