Thank you Thorsten for that info. I was interested in this project but shelved it because I could not source these O rings.3DSonics said:Hi,
I got mine from Wickes, plumbing section, bag of a variety of sizes 99 pence or such.... Picked up a few bags. Once you are shure about the right diameter and you need bulk supplies you can buy from RS Components.
BTW, the 30AWG Silverplated copper wirewrap wire from RS can be used for this cable too, if you strip off the insulation.
Ciao T
For use with FT-125 co-ax, you specify "four rubber O-Rings with an inner diameter a little below 6mm."
Is there a Wickes or a RS Part Number?
Thanks
