Bob McC
living the life of Riley
:d
The DEQX hardware and software is knocking on for 5 years old now. When it hit the scene all those years ago it was revolutionary. In the digital world time isn't kind though.
I think the main issue to take is the 32bit processing(20bit in some places). Nowadays we're looking at 64bit which are less prone to rounding errors and have far higher precision leading to more transparent processing.
Then looks at the DAC's in the DEQX, 107dB Dynamic range and -100dB THD+N aren't particularly impressive now. You can of course add an outboard DAC but you need to figure that on top of the £2k admission fee for the DEQX.
The DSP processing horsepower isn't comparable to today's best solution. This means you don't have the necessary clout to process higher quality filters and the software itself doesn't incorporate the recent advancements in psychoacoustic filtering and the more advanced driver and room corrections.
All in all its looking a little dated now.
For the moment, the best and most advanced correction solutions are all PC based using high quality filters generated by specialist software which are passed through convolvers using the ASIO transport and then out through studio grade soundcards and converters. If this is the route that your wanting to take then it doesn't get any better than this.
I'm an ex DEQX user and can say its a further refinement in sound. Most TACT/DEQX users also seem to migrate to the PC if they find this approach to their liking and others like Mike prefer firmly rooted and mature solutions such analogue.
I think all the digital approaches to loudspeaker and room correction are in a relatively early stage of development. The groundwork has been laid by product such as the DEQX and Tact but the sound and technology needs to mature. There's no doubt that this is the future of the highest fidelity playback, surpassing all others but there's some way to go before that's a reality. Things can only get better right now whereas analogue solutions can be considered mature with very little real advancement in recent years but already the current best digital crossover and correction surpass analogue in some areas.
I'm sure in another 50 to 100 years analogue will have virtually disappeared and there will be impossibly advanced digital methods. Its exciting to be at the start of something that will become the future.
Thanks for taking the trouble to give such a comprehensive reply. What software and hardware do you use? I like the idea of a PC based solution as it allows an easier upgrade path as the technology develops. Is it mature enough for a wider audience yet or only suitable for the experienced diy'r? I can't wait 50 to 100 years for the complete numpty version![]()
Antonio has been banned. Can I remind members that discussion of Antonio/Melorib is against the AUP as he has no right of reply.
