7_V
I want a Linn - in a DB9
Who's the new girl?
Welcome oedipus. Hobby only or are you in the biz?
Isaac Sibson said:Curiously, another AKM chip makes an appearance, the AK4524 which is described as an audio Codec, essentially an ADC and a DAC in the same package. My guess (and nothing more, but the circuit layouts suggest this) is that this does the ADC for the microphone input (for room EQ) and does the DAC for the auxiliary outputs (unbalanced 1/4" jack, vs the balanced XLR main outputs).
Isaac Sibson said:From the top of the board, there is no evidence of output staging, so my guess is that op-amps reside beneath the output board. I would be surprised if the outputs were unbuffered...
Isaac Sibson said:Sound?
Isaac Sibson said:I haven't even touched on PEQ and DEQ yet.
Isaac Sibson said:What I will say for sure is that the user interface is something of a dream. It is very quick, very intuitive and generally the layout of screens and the controls around the screen is very logical.
Isaac Sibson said:Modding potential? Certainly some... finding the output stage op-amps would be a start, as the budget probably won't have allowed for anything wildly fancy (553X at a guess).
Isaac Sibson said:Decoupling caps around those, and the DAC chip itself, as well as replacing the 7805 Vdd reg with something a little quieter...
Isaac Sibson said:Clamping off the SMPS wires and screening the oscillators could go some way, and there's the evergreen classic of clocking (as there are two seemingly dedicated audio oscs, one for 32/48/96, and one for 44.1/88.2). There is also an external word clock input.
Tenson said:So the main XLR outputs and the Jack AUX outputs use a different DAC?
Tenson said:I don't understand the advantage us using a different DAC for the aux and main outs
Isaac Sibson said:and the bits to build some output leads
Isaac Sibson said:Then I'll need to beg/borrow/steal a mic to play with room correction...
Isaac Sibson said:My amp does have one set of balanced inputs.
Isaac Sibson said:I'm opp norf, but cheers for the offer.
Croc said:i see that you have an expirience with DEQ2496.
Croc said:i'm considering it in order to EQ my room in sub 120 Hz range.
i guess that i have to place it between the pre and power and make the whole ADC + DAC.
Croc said:the question is - how is your and other's expirience regarding sound quality?
Croc said:obviosly local DEQx and Tact dealers say that Behringer sounds horrible.
wadia-miester said:Some people think Tact sounds horrible, so it sorta evens out
