oedipus said:
Not surprisingly, people with "good hearing" pretty much like the same thing. People with hearing deficiencies will tend to prefer speakers which act as a prosthesis for their impairment.
This is absolute Bo**ocks
I have the beginnings of high-frequency hearing loss. The last thing I want is an enhanced high-frequency prosthesis from an audio system because:
- it doesn't sound like real life, real music, real instruments, real musicians (this is the prime reason)
- it lowers the dynamic range available between (what you would believe I'd percieve as) 'normal' listening levels and the point at which my ear/brain system really starts distorting
How dare you tell me what I 'will tend to prefer'...
When I was younger (not much younger) I could readily hear:
- 19kHz pilot tones on FM radios
- tube whistle from TV sets/CRT monitors
- whistle (pain) from bird/animal scarers
Sadly this is no longer the case.
But my hearing still tells me that I still struggle to find CD replay systems that match what I hear in real life. And where do I hear the greatest disparity? In the extreme treble (sibilance, cymbals). And what do I hear from speakers with enhanced treble? Even more distorted unnatural treble.
I have never ever seen any information or experienced anything from my observation of other people's likes or dislikes in audio systems to substantiate this claim.
Sadly, I feel this demonstrates just how little you understand about what people really hear.
I also suspect, and this is worrying, that if you did
hear any difference between, say, digital interconnect cables, then you would immediately convince yourself that you hadn't. Surreal.
Off Topic - Subjectivism and repeatably detectable differences...
Let's go to B&Q and mix a couple of similar colours using the Dulux custom colours thingy. We will mix a pair of colours that are only just distinguishable when directly comparing the two side by side. We will demonstrate that these are distinguishable by getting individuals to view the two colours side by side and demonstrate that they can correctly and repeatably identify them as being different in a statistically significant manner.
Let's now take these two colours and separate them, paint additional swatches with them, shuffle them and randomly mix the swatches. Let's get a random set of people and ask them to do serial double-blind tests - ie. only show them the swatches one after the other. This is important, because this is the only way we can do audio comparisons - one after the other.
Now show me the results of the second set of tests. Show me that subjects can readily identify the differences between the two colours with anything approaching the statistical significance expected of db audio tests.
Let's confuse the issue still further. Let's repeat the experiments using blues, reds, yellows, darker colours, lighter colours, metallics gloss and matt colours.
When we created the two colours we deliberately and clearly statistically demonstrated that particular individuals could determine repeatable difference between the two colours. They
are subjectively different. And statistically they
are measureably different
Sometimes when particular individuals tell us they can hear differences between particular items they really can. Sometimes when measurements tell us there are 'no' differences, it may be that we haven't yet worked out what measurements to take. I was told CDs were audibly perfect when they first came out
I was told that I could only detect volume level differences of several dB. I'm so pleased that our technical understanding of audibility has progressed somewhat over the last few decades.
Sometimes, the subjective observation
is correct and the observation itself is a valid measurement. Sometimes it isn't. When enough people make similar observations, it's worth paying attention and trying to understand more. The difficulty is trying to work out which bits
are worthy of further investigation and which aren't. Too many tests seem to be designed to deliberately disprove that there is a difference rather than to really determine
if there's a difference and if so,
why.
Back to Digital Interconnects
- Jitter (above certain levels) is demonstrably audible
- In extremis, an interconnect cable can be designed which deliberately introduces jitter at an audible level
- so we can create a pair of cables which are audibly different
Thereafter, the question is how close in (measured technical) performance to each other these two cables need to be before we cannot detect an audible difference.
And it may be that there are
other characteristics of the cable which (maybe when interacting with the equipment at either end) affect the audible performance.
Another valid approach is to simply accept that designing the cable to minimise these measurable effects is the sensible way of also ensuring it has no audible effects. That seems (to me) to be the approach that Thorsten is suggesting here. And if the design proposed achieves this in a cost effective manner (which is after all the goal of good design, or have I missed something) then why decry it or quibble over the calculations and design concepts involved?
I'm going away for a few days now, too much of my life has been spent writing this post, and I'm extremely busy at work, so - have a chat amongst yourselves.
