I would only be using the sub to catch the very low stuff and dont feel its worthwhile spending fortunes on one.
It is, believe me.
EQ'd bass is the way forward IMO, I am a convert. The bass I get in my system is now staggeringly good.
Many of the developments have been mooted and/or announced by Bruce Hall at the UK's official Velodyne Digital Drive Forum here (be warned, it's a hell of a long read!)
MartinC said:Interesting write-up Robbo, cheers for sharing, and including all the piccies. Having good EQ built into a sub where it can address room resonance issues but without any detriment to the signal to the main speakers does seem a very good idea (assuming the EQ is fast enough, which it must be going by the results).
Is there any spec data given on that microphone? I'm just wondering about the roll off shown on the outputs going up to 200Hz. Or is such a variation normal in room? Might there be any issue having the microphone on a pile of cushions rather than a stable support?
Robbo said:Oedipus,
How are you getting on? Like you I was having trouble with the auto switching on and off, so I have just downloaded and installed the latest version of the software (V1.5) which is supposed to contain a bug fix.
GTM said:If Velodyne know what they are doing
then the frequency response of the microphone will be accounted for in their set up system.
This has a drawback of course, being that the use of another microphone would make the set up system inaccurate. For that kind of money you would expect the set up system to be integrated with the microphone to allow for the microphones inaccuracies. If it weren't I would take the results with a pinch of salt to be frank.
Of course as with all measurements of bass response in-room, the actual response will only be that shown on the setup plot at that point in the room. By the very nature of bass it will vary considerably from point to point around the room. Just moving the mic to the next seat on the sofa would make the plot completely uneven again.
So it limits the usefulness of such equalisation in the real world unless you sit in one place to listen to music in which case it's obviously beneficial.
Personally I would be looking to create a "room averaged" flat response by taking several setup plots around the general listening area.
GTM said:oedipus,
Go look up wave interference. Specifically the interaction of waves of different frequencies in an enclosed system.
I'm not going to bother responding to the rest of the post because of it's needlessly arrogant and beligerent tone.
I'll let you know if it solves the problem
