3DSonics said:
The SLP-98 shows significant LF rolloff into loads much lower than 100K, with 10K load you are looking at -1db @ 30Hz.
I hope this would not be too dramatic for speakers with -6dB@45Hz.
this is the consequence of coupling caps - i will be anyway keen on trying a mod that bypasses them, turning the preamp into non-DC one, gaining speed, dynamics and more freq.extremes.
3DSonics said:
The Cary preamplifier is not one I would select to drive a lowish impedance Pro-Audio input. It may be desirable (in the light especially of the excessive gain of the line stage) to use an L-pad in the form of a 22K resistor in the XLR Plug which raises the load on the Cary Preamp to 32KOhm and attenuates the noise of the linestage another 10kdb or soand reduces the overall gain to around 11db from the well excessive 21db.
you are probably right, T, i've been already thinking about its high gain and i've had pretty similar ideas about putting a resister to raise the load.... although cary has independent L+R gain controls separate from volume, hope this can do some further tuning of the excessive gain
i anyway bought this amp 1) liking a general tone character of older cary preamps such as heavily moded SLP-94 /also meaning that i have someone experienced with cary tweaking near me/ 2) having in mind its great tweaking potential 3) ok i will not mention a low price here
once it is with me, i'll see how it works and then i will try to get the most out of it. i count on your remarks, thanks a lot.
right now i either didn't have a budget and/or access to the preamps that would be a better match out of stock, or just failed to be impressed with these whose numbers seem to be a better match (such as EAR or BAT).
once again, thanks for all these extremely useful remarks!
