LiloLee
Blah, Blah, Blah.........
What has firing out the side got to do with it? Bass is mainly about moving air, so I would have have thought side, top or bottom would be fine as long as the room interaction doesn't hurt the response.
Alex S said:Duncan, You have SBLs. Of course you think the SL2s do bass.
Of course you know that Schubert had very short arms so he couldn't reach the low or high notes.djc said:I wasn't comparing them with SBLs but with Schubert on a real piano, which I am fortunate enough to hear every day
Mister R said:I must have heard these boys and thought they are alright coz. I've got the brochure, but you know what I can't remember what they are like, cost etc...
Any idea if the Amphions would be good for dance/chillout/rock etc? Do like something on the different side of the norm when it comes to buying hifi myself!
Iain
Do we know within what limits the response is 22-20kHz?Snoopdog said:Amphion Krypton driver compliment & published specs:-
Operating principle
3-way symmetric hypercardioic, closed
Tweeter 1ââ'¬Â aluminium
Midrange 2 x 8ââ'¬Â SEAS excel
Woofer 12ââ'¬Â Nomex long throw in stone/mdf composite closed enclosure
Crossover point 120 Hz, 1200 Hz
Impedance 6 ohm
Sensitivity dB/W/m 88 dB
Frequency response 22-20 000 Hz
Power recommendation 50-500 W
Dimensions h x d x w 1350 x 475 x 240 mm
Weight 85 Kg (each)
Dev said:Lee, don't let Merlin hear you say that !!!
Dev said:On the plus side she likes Tannoy TD12s even better.
wadia-miester said:Pimms with those D100's or are you more a G & T man?
