Is this kind of thing sustainable???
Well at least for the 18 months before the battery dies and you have to throw it away! Is that really the case? Seems disgusting from an enviromental perspective if that is the case.
Originally posted by Sauerkraut
Yes I have a DVD player. Lives below my av amp and above my stereo amp. Sounds like a definite candidate for the ERS reatment.
I did cover the inside of the lid of my DVD player, it works a little better than just on top of it...
What did it do... :confused:
It did the same as some very expensive Siltech ICs, for 20 bucks... :MILD:
Lowrider did you use the adhesive backed stuff? If not what did you use to stick it down?
Also any risk of shorting stuff inside my boxes if you put it in the inside? I belive it is conductive?
I didn't get the adhesive back, as I dont usually open my gear... :o
I used that tape that has glue on both sides, and stuck a bit on each corner of both sheets, it took two sheets to cover the lid of my player... :cool:
Only the edges are conductive, I dont think there is danger of them touching anything but the case itself... :rolleyes:
