i use ML Aerius i with two linn lk280's. before that, i tried the naim amps i had. i found that the naims didnt drive the logans to no where near what they are capable of. with the naims they were dark, shut in, v wooley bass, no top end, no imaging/soundstage. sounded shx**e.
after about a 5second listen with the linns, the logans sounded as they should,(no suprise really as they were intended to drive briks seamlessly) very open, superb mid and top end, very tight bass, excellent s/stage (height, width and depth) and brilliant imaging. they are in a dedicated room with dimensions of 6m x 5m. my advice is change your amp, as a dip to 1.7 ohms and a 4ohm nominal is a struggle.
people with logans do like valves, very natural sounding,and proves that you dont need massive wattage to drive the logans, but you do need a high current ability.
imo, female vocal, guitar and piano sound the best ive heared with the logans, tried my bro's tube technology unisis valve amp the mid/treble was there, but the bass wasnt as tight or as fast as the linns. still drove them well though.
stick with them but try different amps, you will be suprised at the outcome and will guarentee that you'l want to keep the speakers.
