la toilette said:.....if you turn them upside down they look like comedy robot heads, which makes them a winner in my eyes....![]()
LMAO but unfortunately, sad ones
Markus Sauer said:Thanks Coda II.
Let me add the Heed Envoy (a bit under budget at 3,150 quid) to the list of suggestions.
Dev said:I think TD10 are £5K a pair.
bottleneck said:if I had to buy new, Id get a pair of these 15" dual concentric tannoys.
http://www.jdsound.com/store/produc...ID=npIaGX5kVtuou7CKPhWQ&SID=2&Product_ID=3356
7_V said:Morduant Short Perf 6
technobear said:...which can be found in the UK for £1721.38 here
sideshowbob said:That's each, not a pair.
-- Ian
Sensitivity of 101 dB. Nice. With an added Velodyne DD15 it's chocks away!bottleneck said:if I had to buy new, Id get a pair of these 15" dual concentric tannoys.
I sit corrected sir.technobear said:The TD10 is £3739.99 - see here http://www.jrsystems.co.uk/index.asp?product=5&make=29
Did you not read the start of the thread?brizonbiovizier said:What is your system, your room size and taste in music? What preferences for exisiting speakers do you have?
