Tenson said:Why would changing the PSU alter the units ability to drive a certain load? Surely as long as the active parts have enough juice to work fully... WAD suggested a cap in the PSU to make it drive TVC's so you could be right. Rob said he didn't have that in there though!
RobHolt said:I thought about this yesterday and there are three possibilities:
1 - All the PSU caps were replaced with Black Gates which have a different spec to the original caps and are slighly higher capacitance.
Tenson said:Hmm how does that change its ability to drive a load though? I mean it could provide a little more current but that is not going to make the difference between motorboating and working perfectly, is it?
brizonbiovizier said:Switch the extra 6db in - it improves pace and drive.
murray johnson said:Rings less like that as well!![]()
murray johnson said:At the same volume level the attenuation must be the same.
How it's done is different though.
Tenson, I'm not sure everyone who's listened to an S&B TVC would agree with you but if you're happy with it that's all that really matters.
Tenson said:F That could happen with a TT but is easily fixed with a filter at 20KHz.
Stereo Mic said:Isn't that filter likely to result in ringing in the audible frequesncy range?
brizonbiovizier said:Well after a false start with some silver mica caps (sounded god-awful) - I am now using some polys - seems to be fine. I am awaiting your contribution tenson ... what about a day next week (except wednesday?)?
RobHolt said:Yes active with huge f**k off heatsinks on the back![]()
Pics tomorrow.
