Sqeezebox help please
St Albans
My SB2 has been happily working for months when on Sunday it displayed gobbledegook and stopped working. I can no longer open slimserver although I can go to the website. I have checked windows firewall which is allowing access and I have deleted and re-installed slimserver. The SB2 will not re-connect to my wireless network.
Any ideas?
thanks
Rod
Might be worth pming andrew1810 on this. Hes been great answering all my questions about squeezebox etc!
Does slimserver open on the PC?
In a web browser, try http://localhost:9000
If that loads slimserver, does it say if a player is connected on the right hand side?
If it doesn't load, it seems to be a software problem.
If it does, its either wireless or firewall. If this is the case, do you have anything else on the wireless network (to check that is working ok).
If nothing here solves it, I'll suggest some more.
Andrew
Andrew
I have tried the local host but it does not connect. My daughter can still connect to the net from her wireless networked pc. I have looked in the firewall and slimserver is ticked to be allowed.
Rod
Have tried running from c:\program files\slimserver\server. It says already running. I can't access the program.
Rod
Very odd, can the Squeezebox access the Squeezenetwork internet radio stations?
That will narrow down the problem a bit more.
Also, try turning off the firewall altogether to briefly test it
I can't get the squeezebox on the wireless network at all. It runs through the setup but fails to connect to the network even though it identifies the network.
Rod
Done that. I have been avoiding removing and re-installing my wireless network but it is looking like I may have to start from scratch. Its the slimserver software not responding that seems odd.
Rod
It is strange that it says it is running, but you can't access it.
If it was a network problem you should be able to access it locally, if it was a software problem, the squeezebox should access the squeezenetwork.
One thing you could try, pull the power out of the squeezebox and when you plug it in, hold down number 1 on the remote, this will reset the chips.
I wonder if we have two problems here, some wireless issue with the squeezebox and then a software issue too.
Have you tried the squeezebox connected to the router via a cable to see if the wireless card has failed?
Also, have you installed any software on the PC since it last worked?
I'm sure we'll get to the bottom of this eventually
Andrew
On the PC running SlimServer, the browser should be able to connect with or without any other network nodes or there even being a wireless network. If it can't then there aren't many possible reasons:
1) SlimServer is broken
2) Windows is broken (does file and printer sharing still work?)
3) The firewall software on the PC is broken or incorrectly configured for SlimServer
On the PC running SlimServer, open a command prompt window and type 'netstat -a'. This will list all the open ports on the PC. You should see some for SlimServer, particularly 9000. If you don't then SlimServer is not working correctly or the PC firewall is preventing it from opening ports.
I am using the windows firewall although the router a Belkin has one. I have tried turning off the firewall and then opening the SB software but this did not make any difference.
Rod
