Sqeezebox help please
Rodrat, hehe, yea its something that allows you to successfully play music. Snigger.
Andrew, thanks for the software. I still cannot connect to the slimserver despite the sb connecting to the wireless network.
I am going to format my hard drive as it is due anyway and hope a complete reload of everything ( bar the crap) will sort out the problem.
Is there a means of resetting the sb to factory settings?
Garyi
I have been to a secondhand shop and bought a cd player thing. I asked for some discs (man) and they sold me some big black plastic ones. Once I have sorted out how to put them in I will have music again. I am assured that Englebert Humperdink is a happening dude.
Rod
If you just unplug the squeezebox from the wall and leave it for 20 mins or so it should reset automatically.
You could also try SlimCD (a bootable linux disk with slimserver built in) to see if that fixes things.
Andrew
