Dave Simpson
Plywood King
We were discussing amplifiers and speakers.
It appears IMD, HD and FR and other non-linearities are as good as we're going to get for an explanation as to how you can turn a Technics receiver into a Naim 52 preamp and ATC poweramp pack. No worries gentlemen. That reply confirms what I suspected we actually know about audio.
Thanks Simon and everyone. Please consider the matter closed.
regards,
dave
I'm still a bit confused though. It seems a bit odd that we're having trouble precisely defining the parameters that prove we know everything there is to know about perfect audio reproduction or that all amplifiers sound the same. How do we know our assumption is correct?
Apologies for any dodgy spelling as I've just banged this out on some fartly little portable device.
Oh really, is that something new?
I love my little Viliv device, I'm using it now. I started ripping all my CDs two days ago to a portable 750GB drive connected to my router as you have done. iTunes ability to find artwork is not good though, I have about 20 CDs on there now and only 3 with the artwork! I did start at the old and obscure end of the collection though.
I also got the mobile internet via a sim card working. It does about 4Mb/s! Chufed![]()
I'm relieved you are not of the opinion that all amplifiers sound the same. TBH, I was under the impression that was your belief and that's what provoked my first post on the matter. I'm glad you've set the record straight.
Regarding your opinion that most competent amplifiers have differences which are negligible or unimportant, I have no problem with that. We all have different values.
Ah yes, people will attribute all sorts to others in order to make a point. I've never said that there are no audible differences between cables either, simply that all audible differences are due to understood and measurable factors. IMO most have close enough specs that the differences are inaudible but you can certainly find examples of cables that change the sound.
That is consistent with my views on most audio electronics - that we have reached the stage where kit is pretty much interchangeable with the difference being so small that they go unnoticed, but there must always be a basic level of competency. Analogue source components and speakers are a different kettle of fish with often huge differences and that is where I put my efforts these days. I think we pretty much 'sorted' amplifiers back in the late 70s and digital audio in the late 90s so long as you are avoiding kit on the lower rungs.
I have an old Kenwood amplifier (KA1200) that sounds pretty rough. Doesn't measure well though and I certainly wouldn't claim that it sounds the same as a good modern amp. However, I do know why and for me that is key.
Do read the Self books though Dave. Even if you end up rejecting his finding it still makes a thought provoking read.
regards,
Well I don't think Rob was referring to valve components.I pretty quickly notice the difference between my valve amp and my old cyrus one, Rob, if I have to use it.
In this category there can be big differences especially amps.
Valve components are known to be musically colourful.![]()
Agree entirely titian.
I'm not commenting on personal judgement either and perfectly understand why someone might prefer 'colourful'.
regards,
Then you make my point perfectly David, because I can assure you they'll measure very differently, unlike those examples in the list I posted yesterday.
It's not just a matter of measurable parameters. It's under which conditions those parameters are measured.
A £200 amp may well measure identically to a £1000 amp under lab conditions if fed with a single frequency sine wave in to a purely resistive "ideal" load for example. However, there may well be measureable differences between various performance parameters between the two amps when fed with a more complex / demanding input signal. (even when short of clipping the input), in to "real world" loads as presented by a speaker/cable combination.
In the same way for example two cables may well measure identically with respect to frequency response under certain conditions but may well have differing effects on the overall performance of a "system" when the electrical characteristics of the specific input/output circuits they are connected to are taken in to consideration.
My only point being, to determine the "affects" of any particular part of a system you need to consider all of the variables. This is as true for a "Hi-Fi" system as it is for any other electrical (or otherwise) system.
I'm not aware of anyone who doesn't believe measurements are important including those who believe many components and cables sound different from each other (the magic circle folks?) I simply find them meaningless for telling me what a component actually sounds like other than obvious quirks with wild swings in FR perhaps. They're more useful to me as an end user for determining compatibility.
Any magic circle friends disagree?
That actually answers my first question on how you can modify one amp to sound like another;-)
cheers,
dave
