Gentlemen,
What are your thoughts on microphonics with solid state devices? I can hear a difference with a weighty object placed atop my CD player, preamp or power amp but not on my tuner. The same is experienced with the supporting platform underneath.
regards,
dave
The CD player contains moving parts so it might explain the difference. A null test would prove the point conclusively.
With electronics in particular I'm not convinced there is any issue.
Some evidence exists that early dac chips were microphonic, but then only if you were thumping the chip IIRC so not sure how important that is.
Regular line level circuits and power amplifiers though - never experienced a problem.
Tests for this would be extremely easy.
For example, take a pre amp, short the input and wind the gain to maximum. Record the output digitally with the pre amp sitting atop a silent loudspeaker, then repeat the recording with the speaker playing. Compare the recordings for differences. No reason why you cannot also do this with integrated amps, power amps or phono stages.
That test is under far more hostile conditions than the norm.
One further thought.
Even if we were to find some evidence and get a positive result from the above test, it would surely be several orders of magnitude lower than with tube equipment.
I rarely see people complaining about microphony with their tube electronics even though it most certainly does exist.
Therefore I'd be inclined to file the question of SS microphony under 'not relevant'.
