- Jan 25, 2004
Have you ever heard any Chesky recordings? They are the most unnatural sounds I've heard.
is that a bad recording then?
Hi Joel,joel said:One that comes to mind is the Diary of Alicia Keys. This is an album that has some good ideas, but which has had the life squeezed out of it.
No need to put it diplomatically bub. It sounds fine to you, no doubt as you're driving into work.The Devil said:Hi Joel,
Erm, how do I put this diplomatically? The album to which you refer sounds very good indeed, on vinyl, anyway.
Saab said:is that a bad recording then?
Just a couple of points:Bradders said:If loads of your music sounds crap on your system - you should do something about it because it doesn't have to be that way.
joel said:Most pop music is designed to sound good on "shitty" systems
joel said:Most pop music is designed to sound good on "shitty" systems (like mine, apparently). So, following your logic, if pop music sounds good on your system either you are deaf, your system is shite or both![]()
Which is it with you, Bradders?
Urrrr....
I said I couldn't comment on the sound quality of pop music recorded and produced for kids (I think there is probably a difference between 'pop music' and music for children). Then I said that when discussing music of any merit I didn't believe that there were many bad recordings out there. If you are listening to music produced for kids, then fair enough, it might be poor.
My system is alright, I can listen to all my records and they all sound good to me.
Music can be made so it sounds good on any system. It's just a lot easier to make it sound hot through a pair of videomaxes and in the car stereo, and f**k the rest. Most labels and artists want their track to sound louder over the radio and on MTV than those of their "competitors", and lots of engineers lack the art to do it otherwise. I was listening to Truffaut interviewing Hitchcock about the production of Rope (Hitch's first colour film, shot as a "single" sequence), and Hitch's major complaint is that most of the cameramen of the time, while having plenty of "trade", totally lacked "art". So it is in music IMHO.PBirkett said:I've never understood, or agreed with that comment.
julian2002 said:most 'shitty systems' (i.e. factory fit car radios, boom boxes, micro systems etc.) have very rolled off frequency extremes i.e. no bass. if a recording was made untouched then you'd not be able to hear the basslines for most of these songs. so the engineers 'boost' the mid bass and turn down the real bass to allow these types of equipment to cope. also 'louder is better' so compressing the music allows these crap systems to be cranked to the max without shooting a bass cone through the back window.
hope that explains what and why engineers do what they do. as for whether it sounds shit or not, well......
julian
I don't think they think in terms of crap or great hardware TBH. From the perspective of the engineer/producer/artist that is such a huge black hole it isn't worth thinking about. My problem woith the Alicia Keys album is that the entire album is mastered like a radio/MTV mix. This is not clever.PBirkett said:That perhaps suggests they simply did not put the effort or had the budget to make it sound good, rather than going all out to make it sound good on crap hardware.
Both my systems have loudness and tone controls; This must be why they're crap. You never see tone controls on British mixing consoles, of coursePBirkett said:But most "crap" systems have loudness buttons, EQ's or tone controls anyway.
joel said:This week I've been listening to some superb minimalist low-budget pop albums from the late 70s/early 80s. I suspect that Young Marble Giants, Au Pairs and Dalek i simply didn't have the money to f**k too much with the sound. The results are brilliant (and not in the least "Audiophile").
