7_V
I want a Linn - in a DB9
I am an advocate of smaller, high excursion, low-distortion bass drivers.Originally posted by titian
Just don't forget as I wrote somewhere before that every driver which is bigger than 12" 'break up' the cone. This means that when looking with a strobe light, the cone doesn't move up and down as a unit. You see waves in it. Especially very light cones break up and this makes lot of distortions. But this makes some colouring which is though very appreciated by lot of people.
The main reason that I use 8" drivers is because they require a smaller box and can be used in a modular fashion. The 8" driver used has more excursion capability and lower distortion than many 12" - 15" drivers, so four of them could go in an 80 litre enclosure and be the equivalent of a single 16" driver (and move as much air). Also, the cabinet vibration can be dramatically reduced using multiple smaller drivers.
However, in fairness, it's very unlikely that a well designed 12" or 15" bass driver will exhibit much cone break-up at the sub frequencies we're discussing, although there may be some flexing.
Cone break-up has received some bad press but it's not always as negative as its name implies. At bass frequencies you want the cone to act as a rigid mass, because even a small amount of flexing in the cone could lead to a less well-defined bass sound. However, at high frequencies, if the cone moved as a rigid mass, the sound emitted would become more and more beamy (directional) as the frequency increased, until you'd need to hold your head in a vice to get decent treble. Controlled break-up looks like symmetrical ripples in a pond and sounds quite natural, particularly when the cone is damped with the right snake-oil.
