Auditioning the MEG RL-901K
Two sets of measurements produce the same finding about midrange distortion. Thats strong evidence even if the conditions werent identical - precisely because the conditions werent identical.
brizonbiovizier said:
No that would have been a lot more money - plus I preferred the st range to the sst. I will convert to active myself when the warranty runs out. Apparently the bryston crossovers included with the pmc active speakers is not the same as a 10b.
It seems like a huge waste of money to passively tri-amp a loudspeaker. When you consider the cost implications of the PMC's and three Bryston power amplifiers, surely you could have opted for some real flagship loudspeakers that required less complex amplification?
You still going on and on about "midrange distortion"? You are living in a fantasy land, dude.
When do the biscuits come round?
Mr Dev, please PM me about where I have neglected the AUP.
I would like to point out that I have been labelled as a "liar", and you have failed to delete that accusation. A level playing field would be nice.
3DSonics said:
Dear Sir, I MUST call you a shameless BLIAR. I must aslo present evidence to back up my claims, to avoid being charged with libel.
So, read sir, I must declare you A LIAR and a COWARD, coward on the account that you where unwilling to stand up for your loose mouth when called out on it.
This sort of hysterical nonsense doesn't conform to the AUP, but it is still here.
Biased moderation, if you ask me.
Stereo mic, do you mean even larger PMC's, or was that a little swipe, suggesting another brand may be preferable? I can't see any sane person having larger speakers than brizon to be honest.
With regard to tri amping, I personally find the idea of the extra cost, extra cable and extra space to be a nightmare! I'm happy if the changes are worth it for some people, however I'm sure it's a clear example of diminishing returns at work.
I know a (nutty) guy who upgraded from large passive PMC to active PMC. He didn't do so on the basis of sound quality. In fact he makes no claims regarding an increase in quality at all. He made the change due to power handling requirements. Previously he managed to melt the passive x-overs due to their inherent heat wasting design, plus the prolonged high volumes he was running. The active version runs much cooler, so eliminates this problem. I presume this is why a lot of clubs, studios and PA applications use active rigs as a safety precaution.
Secondly I have been told by an employee at Cornflake (Dominic I think) that taking PMC's to active setup is not always worth it. In his opinion using six monoblock Bryston amps with large PMC's can sound quite impressive, but the music is more seperated, rather than the more cohesive sound you get when using just one pair of Bryston monoblocks passively. I can only assume that going active will be an improvement for some people, but not eveyone. That's a lot of extra mess, space and money to find out!
