I-S
Good Evening.... Infidel
Johnny said:you use silver instead of copper.It has a higher ratio of direct current to voltage,
Is this different to resistivity and if so, how?
3DSonics said:However, truthfulness to the actual recording is another thing.
Tenson said:I have had this discussion with T before and I think it boils down to this. If you want truthfulness to the actual recording, then you need to eliminate room interaction as much as possible. Highly directive speakers do this. Especially those with an even off-axis response. This is brilliant for studio quality control monitors.
BUT, this does not mean you are hearing the recording as intended by the artist or engineers. When the recordings are made they expect a certain amount of room interaction such as high frequency reflections. From our understanding of how our mind hears things, we can create the conditions such that you can have this expected room interaction and still maintain the ability to hear every detail and all that in the recording.
So really when T starts on about speakers not being competently designed... I think he should really only say this when one specifically states they want truthfulness to the recording, not necessarily what was intended to be heard.
Tenson said:BUT, this does not mean you are hearing the recording as intended by the artist or engineers.
3DSonics said:Simon,
Well, we have around four general options as to how a recording went....
1) Basically untouched - direct minimalist recordings
2) Engineered using acoustically treated control rooms with large, fairly directional studio monitors
3) Engineered using nearfield monitoring
4) Engineered in acoustically live rooms using "HiFi" Speakers and other oddbals (omni's etc.).
Of the above 1 to 3 (which covers probably 70% + of all recorded music) require normally that room influences are minimised if wewant to hear what was intended. In case 4 all bets are off (of course).
We can minimise the room interactions at the source (speaker) or by treating the room.
But as said, if someone likes their Mahler served with extra reverb sauce who am I to argue with it? Of course, fidelity of any concept or level it is not, but if it is enjoyed.
In my case having spend quite a few formative years in pro-audio and recording I prefer "studio monitor" style sound most of the time (more in the line of Urei, Tannoy, TAD and MEG though and not in the lines of PMC, ATC and BBC).
Ciao T
ShinOBIWAN said:My own opinion is
ShinOBIWAN said:Like I've already said, I'm quite sure that what I have right now measures better than Thorstens effort in a number of area's and in terms of 'ideal'.
3DSonics said:Hi,
Your own opinion.
And I am certain (I merely need to look at the design) it measures rather poorely in other areas.
Design is a tradeoff, always.
The 64,000 Dollar question is which tradeoffs get us closer to the truth and equally closer to what are looking for sonically....
Ciao T
Ciao T
ShinOBIWAN said:Besides its common knowledge that fullrangers are deficient in the area of distortion, not my opinion.
ShinOBIWAN said:You already know that balancing distortions of different kinds (cabinet, driver, room etc.) is a delicate balancing act with no 'right' way that can be applied in a broad and general fashion.
ShinOBIWAN said:Have you considered that I use a comprehensively treated room with unconventional digital filtering for both the loudspeaker and the room?
ShinOBIWAN said:So why proclaim your recipe is closer to accurate than any other competant brew?
Isaac Sibson said:Is this different to resistivity and if so, how?
3DSonics said:Hi,
This "common knowledge" seems right up with some other items of common knowledge that are utterly wrong.
The level of distortion in a driver mainly depends on motor design. The Driver I use has 1/" linear throw (peak/peak) with a cone just a little shy of 8" cone diameter. You need a lot of SPL before distortion becomes significant.
As always, the key is implementation, not principle.
Yes. I did that in the mid 90's for a friends studio even involving similar midrange drivers to those you use. And no, I do not feel it was/is as good as a good quality full range setup, but it had to answer greater SPL requirements than my home system, due to a larger and fairly dead (and thus absorbent) room where you needed a lot more SPL from the speakers than I do.
ShinOBIWAN said:Using a single drive to cover such a large range is a good idea in terms of phase and tonality, it isn't however comparable, in terms of distortion, to a competant 3-way design using drivers to cover dedicated ranges, with a mid for the most important region and a conscious effort for flat power response.
ShinOBIWAN said:the B200 sound substandard to me.
ShinOBIWAN said:Mid 90's?
Your comments are largely invalid from my experiences. Digital filtering technology, power and quality has moved on in leaps and bounds since that time. And in particular, much advancement in time/amplitude based correction. Maybe revisit the whole thing and your opinion will be more relevant.
ShinOBIWAN said:It sounds like we're both having fun eitherway so I'll leave it at that.
3DSonics said:Hi,
The Driver I use has a LOT more excursion than your Midrange so it does not need to be "protected" from bass. Past that, I am of course running a 3-Way system, however the "midrange" operates without filter....
To me as well, hence I do not use drivers like the B200....
The X-Over used then was BSS's top of the range. It is still competetive against current readily available digital crossovers and in fact has ALL the functionality (time alignment, multiple parametric EQ's per channel) found in current day designs. Only the price has dropped significantly since then.
If you do the whole crossover on a PC (or Mac) you can improve on this, but only at significant issues around usability and all around sound quality.
ShinOBIWAN said:I was talking about distortion not excursion.
ShinOBIWAN said:Not comparable at all if this is what your referring to:
http://www.bssaudio.com/includes/product_sheet_include.aspx?product_id=30
These are what I use:
DEQX
http://www.deqx.com/pdc26.html
