ShinOBIWAN said:
Your shifting my original argument. Accessing distortion based on excursion for a fullrange driver vs. a midrange driver in a 3-way is pointless since you've completely neglected to mention the dedicated bass driver which is very likely to be more compentant in its operating range because its electrical and mechanical parameters can be optimised in favour of just the bass range without looking toward the upper frequencies too.
But my bass driver is bigger than yours.... ;-)
And yes, I have two as well.
ShinOBIWAN said:
Many dedicated mids have SPL and distortion capacity to belittle the fullrange in the same operating range, they don't need the displacement because it isn't needed and actually benefits performance in its optimal range.
Alas, most dedicated midranges do NOT have the SPL capabilities of the Driver I use.
It relates to "normal" Fullrangers about as much as your ATC 3" Midranges relate to "normal" Midranges. Therefore talking "commonplaces" has little benefit in context.
ShinOBIWAN said:
Its not comparable at all, for a start you wouldn't have had access to FIR filters in the mid 90's.
And FIR filters are of extremely limited utility.
ShinOBIWAN said:
It lacks any DRC or correction functions of substantial benefit, PEQ isn't what I use. Its time alignment abilities are basic at best.
PEQ used correctly can come very close in results to DRC algorythms as used by TACT (and I suspect by DEQX). Using excessive resolution in the DRC filtering means you have a perfect response in one spot and there only with the response anywhere else pretty fubared.
The time alignment abilities of the old BSS unit was perfectly usable to make sure you got a reasonable squarewave through the system.
ShinOBIWAN said:
It lacks the capacity to perform detailed and accurate measurement in a real time manner.
We used a TEF for measurements.
ShinOBIWAN said:
Also £3.5k back then isn't £3.5k now.
I realise that, however a lot of that money was in the analogue and AD/DA stages, not in the main CPU/DSP.
The point remains, I have used techniques very similar to yours a long time ago. I would use them again if I had a suitable application, however I prefer different methodes nowadays.
DSP and DRC are useful but they are not a replacement for good basic design.
L8er T
