Isaac Sibson said:Again correct, you haven't. That's totally irrelevant to resistivity. You would only need to specify those things in order to know resistance
Johnny said:Who heard his system ?
and which system ?
Tenson said:I did. His home set-up. I said to Shin that when I played some punk-rock it didn't sound uncoloured or particularly low distortion as it got pretty muddled.
3DSonics said:Hi,
Yet when we played some large scale classical stuff did the tutti's appear coloured or muddled? Just wanting to know...![]()
Ciao T
3DSonics said:Hi,
Funny how quotes change, I would be surprised if you had described me to anyone as "full of it"....
Ciao T
Tenson said:I would put much of the blame on the valve amps, but he doesn't seem to think this is so.
Tenson said:To be honest I can't remember! I'll have to have another listen.
Markus Sauer said:We played neither punk rock nor large scale classical, though.
Johnny said:NO. The definition of Resistivity is resistance of the cable(in this example) which is 1 metre in length with a csa of 1m^2.
Do I need to specify length to know the resistance of a component, say a resistor ? Of course not.
Johnny said:It has a higher ratio of direct current to voltage,
Johnny said:Thorsten, please explain to Isaac why he is wrong. He seems to be hard of understanding.
Johnny said:''If you were making a resistor out of a single piece of wire, yes you would. The question was asked in the context of a cable so yes. ''
heard of ohms law ?
v/I =r ?
it doesn't state anything about length, it gives a simple relationship between v , I and r.
