3DSonics
away working hard on "it"
Yes, yes. And you're the same bloke who reckons the best place for an LP-12 is on top of a speaker? Yes?
Case rested.
Case rested.
3DSonics said:Yes, yes. And you're the same bloke who reckons the best place for an LP-12 is on top of a speaker? Yes?
Case rested.
zanash said:I was going to set up a poll ....as this seem a contencious issue. But I can't see how to do it.
My questionaires ......
1.Do cables make a difference ? yes/no Yes
2.Which cables make the most difference? IC's/Mains/speaker
As a percentage what difference does best cable make ?
IC's....................25%
Mains.................10%
Speaker...............15%
Digital..................5%
3.Have cables ever made your system sound worse? yes/noYes
4.Idealogically cables can't make a difference ? yes/no Yesif I understand the question - I think they can?
5.Have you ever tried any after market cables ? Yes /no Yes lots
6.What IC cables do you use? Out of the box/ DIY / After market/ Custom made. DIY
7. If you were to rate your system were would it fall.
High end................................low fi High-ish
8. And an indication of system worth
5000+.......2500+.......1000+......500+....... 5000+
I hope this is of interest.....if anyone has any suggestions feel free to speak.
Well it's a good place to start, if you want to demonstrate the effects of isolation on this most excellent turntable.3DSonics said:Yes, yes. And you're the same bloke who reckons the best place for an LP-12 is on top of a speaker? Yes?
Case rested.
zanash said:Garyi....I notice that you have not bothered to make a useful contribution to this " bloody Survey" as you so nicely put it.
HTH. Gregzanash said:My questionaires ......
1.Do cables make a difference ? YES
IC's....................30%
Mains.................20%
Speaker...............40%
Digital..................10%
3.Have cables ever made your system sound worse? YES
4.Idealogically cables can't make a difference ? Need to rephrase question
5.Have you ever tried any after market cables ? YES
6.What IC cables do you use? Out of the box YES / After market YES / Custom made YES.
High end................X...............low fi
5000+
How do you infer this?Now more intrestingly those that said cables made no difference also thought there gear could not be bettered.
greg said:4.Idealogically cables can't make a difference ? Need to rephrase question
zanash, you started the 'discussion' with your interim results post above. You can't expect to discuss the results yourself without people responding.zanash said:If you wish to discus things....please set up your own thread !
I'm querying your interpretation of your questionaire, in response to a post you made on this thread. Seems quite reasonable.Keeping this for the questionaire.
Carl said:Hallo Notaclue,
When you hear a diference (double blind) then there is a difference even when you cannot explain it. As a consumer I do not need technical evidence to hear (double blind) differences.
Do you consider twisting cables, silver, carbon as manipulation?
Carl
