Julian's Speaker Build Diary....
And part one is over....
well both speakers and stands are now finished to the first phase (bar running in and tweaking).
once i've got past xmas wallet intacto i'll be saving up to finance an external crossover and then to get them into a slightly more aesthetically pleasing state (although they are in the bottom 10% of lawrence speakers imho and painting them isn;t going to make much of a difference).
i've left the stands empty for the moment and just blu taked the tops on i'll probably mass load them later on at some point either with sand or gravel or whatever i can find.
i went with 3 spikes in the end as that's going to be easier to level and with the speakers just sat on top they were never going to be stable. my daughter has been warned to be very careful around them and was fine with the wobbly missions so things should be ok.
many thanks for the advice, encouragement and well wishes from everyone during this project. hopefully it will inspire a few others to have a go themselves.
the last fest piccys
feel the depth of my fully operational transmission line.
new system pic - all is right with the world....
i need a bit of a lie down now...
julian.
You know Ian,
I'm sure I've crossed paths with Sun-ra before, now you've shown the world his 'Brillance' he's another astral traveller, his music is so way out, it makes beyond the rim seem like a trip to the tab kabin
Nice work Julian - congrats :) . Before tackling the aesthetics of your speakers might I suggest that you have...ahem...curtain issues? :D
thanks guys,
dev, i'll be extending invitations in the next week or two once i reckon they're run in and i've played with the wadding a bit.
julian.
Nice one Julian.
I bet you're really happy to have some full range sounds back in the living room.
Chris
AK,
this is part of the problem i've been having. the width and depth would be fine but 2 inches just isn't high enough to fit the inductors / caps that i'd like to have in the improved version. the box would ideally be about 350x350x200 mmthis would allow me to have room for decent internal paritioning, shielding, big caps and inductors and hefty wires. as well as decent connectors on the outside.
julian
So how do they sound
Julian
So what are first thouhts on the sound of the 5tls - I am still astounded by my 4tl's and once finished they wlook fab too.
Gideon
Julian, buy a router from about £30 a set of cheap bits, £15 and some mdf, make yer own, isn't even as difficult as your speakers, you can use any thickness of mdf, 18mm might be best, the router allows you to finish to a proffessional standard and is pretty easy to use, that's what I'd do. Whole lot for less than £60 and can be fiished to match your speakers, also having the router would allow you to do the edges of your speakers too, and then they'd be no stopping you, you'll be making your own furniture next. if you can do those speakers, you can do anuthing(almost)
