Dev
I think he's already got a wife Antonio.
LOL
To remove the sucker I have to remove the PCB, quite dangerous, because of whatever connections underneath, C3 I had to cut...![]()
What is the problem with higher gain, I already use SIEMENS E81CC triple mica...![]()
C2/4/5 are WIMAs, I know they are nothing special, but they are not too bad either, so I am told...
I have been using it in triode mode since I tried it again, after removing NFB, as I said then, now it improves the sound without softening bass, particularly significant more body...
Already took many risks, I will wait for a good audio engineer to visit Riga and do those more "complicated" changes, arent you coming to Riga, nice place...![]()
You could probably just "pull" the capacitor off by force, they come apart and then just remove all the littlke bits they leave behind.
I will do that as soon as I get home tonight, then report back, thanks...
I did exactely that, made sure no bits of wire stayed in the amplifier, connected, and...
There is a lot more crackling noise from both channels, and some hummm only from the right channel...
It is not loud enough to disrupt music listening, but it is much louder than the very slight schhh I had before...
Christ if you have to smash it to bits and rip out half it's guts, you have to wonder whether the designer knew anything about audio. Chinese?
I am going to rotate the E81CCs to see if the hummm changes too...
I am using a Linn Unidisc SC player/processor...
PS, I have been interrested in the Classic Range of Amp's, may get one just to fool around....
Actually, in Riga you should find an old TV Repair guy who learned his trade under the communists, he should be able to do this easily for you.
I hope this does not use a digital volume control.
You may find a "passive" preamp using suitable quality components to work better...
all he has to do is to walk into radio riga technical dept and just ask for a contact with any of the technicans over 55-60.
this is peanuts for them.
just as a hint to what can be expected, here is what is being now built by a retired engineer from radio belgrade (ignore the language):
http://www.tubeaudiolab.co.yu/index.html
jean hiraga raved about his 6L6 PP amp in revue de son:http://www.tubeaudiolab.co.yu/hiragatest.html
Listening impressions, obvious differences:
- More noise, before couldnt hear 1 meter away from the speaker, now can hear it up to 1 meter, aligned with the wizzer cone, if I raise my head I dont hear it even close to the speaker, probably not bad for tubes and 96db speakers...
- Frequency balance tilted down, apparent less highs, more bass...
- Less "damping", bass and precurssion not as sharp, like when you do a tweak wich limits high freq output, sound appears slower, less lively, but many times it is just less distortion...
Timbre didnt change significantely, midrange sounds very full and natural, silky highs with all the detail...
Suggestions, please...![]()
Tube CAD simulation of the input 12AT7 Totem Pole Amplifier, with and without the input CAP:
Freq -3db high: 93.7khz - 166khz
