Shiner ......
I'd have thought that with just 20 posts under your belt, you would perhaps have shown a little humility.....but then that says more about you than your actual posts.
I don't willingly spend my hard urned cash on things that don't work. I've thoughly investigated ...using contol discs, other people ears and systems. In one instance not even telling them what I 'd done ...just getting them to listen to the two identical recordings , with one disc lathed the other not. The treated disc was picked out within 30 seconds.
I suggest you take up wm's generous offer ....though I doubt that you will . Seems to be a trait of the naysayer that any offers of "enlightenment " are soundly rejected.."as I know it can't possibly work" ....that was the phrase that mosfet I think used last time when I offered to send him a green pen, gratis !
If I have reduced the life of the cd's, but they sound considerably better ...well thats my risk. But this should not be used as a reason to say the lathe doesn't work, as for me and other it plainly does. Its not my problem you [shiner] is unable to hear it for what ever reason. You'll be saying next that changing the power cables makes no difference !
