Thanks for all your ideas guys.
I spent virtually all of my evening playing with the setup of my system.
In short, I did the following:
- Checked for the room nodes by walking around. I found that the wall perpendicular to where my system presently sits had a better node.
- Moved the speakers to the wall with the improved node. They'd previously been sited either side of the TV. This meant that they would be a similar distance apart, but with nothing in between them. In addition, the speakers would be firing down the length of the room. As my room is only vaguely rectangular, hopefully the curvature on one of the walls would help defuse normal sound defractions. In addition, the new siting for the speakers would be well away from side walls.
- Seperated out my stereo components from the AV gear. The stereo gear was then setup in a different location and using a different wall socket.
- Tidied up all the cabling (well it might make a difference)
- "Tuned" the shelves on my mana amp stand (supporting my stereo gear)
- Tested the speakers sat both on and off the concrete slabs that they'd previously been sat on
And the results:
Well overall a massive improvement. The treble is now back to a normal level, and the bass has been given a little boost, resulting in a much better rounded sound.
The concrete slabs were an interesting area. With them the sound is brighter, but also better controlled, and appears to have a better sound stage. Without them things sound more natural and the treble doesn't try to rip you're head off.
Not having a huge 32" TV sat between the speakers made a massive difference to the sound image between the speakers, far better placed and more natural now.
So I'm knackered, but feeling much happier. Along the way I've ended up screwing up the sound of my AV system (my rears have now moved to the fronts and I have no rears), but frankly I don't care as the benefits to the stereo system were worth it.
Thanks for all of your ideas along with others that I've read over the last year that I've been frequenting the forums. Thanks also to WM, who for me has set a sound benchmark of just how good CD can really sound. Without that benchmark, I'd have been struggling to get a sense of perspective about what route I want to take with the sound in my system, and also to be able to spot easier where the weaknesses are.
Thanks also to Zanash, who I now chat with very regularly and is sending me an updated interconnect to route between my CDP and amp. In addition, I'll be popping over to see him shortly as he's going to fit the new "low jitter" clock that I bought last month.
