Fat lot of use that is to me!![]()
Howard recently said something that made me chuckle, that was
"I'm a good lover.... I should know"
Yeah but appropriate music is all part of the foreplay process![]()
I'm going to sulk now because I only have 10 inches
:cry:
15" paper cones yes and if you look down the tulip on the 15's they have a small bullet shaped centre piece to the waveguide-the other TW DC's don't have it FWIW
Cooky
The 12" does have it, but it seems to be different shaped to the 15" you can just about see the tip of it in the attached pic:
The different shape of the 15" is probably there to match the treble dispersion with the bigger driver. Regardless, the treble on the DMT12s is absolutely top notch. very detailed and lifelike.
The Velodyne DD12 will probably go though.
Congratuations on your new speakers.
The DMTs are proper speakers in the sense that they are big (often a good thing), have really high-quality inert cabinets, great drivers and a well-balanced, very dynamic and accurate response.
But they need more power than their efficiency would imply and their stock crossovers, while good, are not quite up to the same standard as the rest of the speaker (but can be upgraded). They ideally require subs (apart from the 215, perhaps).
But they are definitely a bargain, especially s/h, as you get far more bang for your pound than with most domestic speakers. No question.
Cooky is the expert on this range, far more than me.
That's really low. How far are you from the speaker?
So what do you use? A bit of Barry White, or Marvin Gaye?![]()
The quoted frequency response will be the -3db anechoic measurement. The in room response will be significantly lower than that depending on room size etc. Also, most manufacturers quote the -6db value to make out the speaker goes deeper.
