- Jun 19, 2003
Hi Chris
No. i don't think so. My first turntable was a Garrard GT255. I got this in 1981. I was cheap (£45) & it played my records. It helped form my first system. (Nikko Na390 amp & Omar Goring speakers).
I my student days, I went to a AR turntable with Mission 774LC & Nagaka MP11. I went to a Elite Rock II with the same arm & cartridge. The differences were very noticable. Better pitch, less blurring of notes, less bloom in the bass etc. Better account of the information on the record. I then, at a later date, went for a better arm then a better cartridge.
I heard how turntables could influnece the sound quality & also how the perfromance can change depending on arms & cartridges. I have always looked at the deck, then arm, the cartridge.
This is not the way I would do it. This is not to say that it would get some good results. You would be up to the mercy of your choosen deck & arm. A lesser deck & arm will show up less differences between cartridges.
for example, If I heard a Ortofon Jubilee cartrdge (£1500) in a high end turntable/arm combination with a high quality tailored phono stage & liked the combination. Then all you could afford was a Project Debut. Would a Jubilee/Project debut setup out perform, say, a Gyrodeck/Rega/Ortofon Kontrapunt A? These are of a similar price.
The Project would struggle to handle all the extra info from the Jubilee. The arm on the Project would not be as good as a lot of better arms. Also the bearings would be as good. This would give you a lose of infomation & the addition of resonances. This is an extreme example but it does highlight a few points.
The cartridge interface with the phono stage is important but I would go with the turntable first.
This thread seems to be turning into 'what would I do different this time round if I could' ?
Audition phono stage and cartridge combinations until I found a pair that dovetailed perfectly.
I would do this on a deck that was absolutely superb and totally out of my price range ! - like a platine verdier or a SME 30 or similar..
Then ! - I would try the cart and phono stage on decks/arms that were within my budget until I had the best sound at my price point.
