LiloLee
Blah, Blah, Blah.........
I can go with this. Sounds plausable, except we all know transports don't make a difference
BlueMax said:The three cables were conected to a well shielded gang socket I made up. IEC connectors of these were left right behind the amp for fast swapping over. Same tracks were played with each cable. Only I knew which cable was being used. Ratings (1-5) were noted on a table.
Four different CDs with classical and instrumental jazz music were used.
Tom Alves said:Electricity flows in one direction, after awhile the metal molds to that flow.
I did not tell them anything about 'burn-in'. They wouldn't know what it is. I just told them that I am testing some cables. Though my g/f has previously seen the cable 'being cooked' in the kitchen and wondered why.wolfgang said:Thanks for the elaborating. You seems to be more 'serious' them most and genuinely interested to find out whether this theory is true or not. I presume you did tell you friends before starting the listening comparison that although they are made from the same cable they are in have been 'burn-in' by different period of time. And all of you wrote down the score without conferring until the end.
Tom Alves said:FWIW my guess is that it has something to do with electron/crystal structure allignment. Electricity flows in one direction, after awhile the metal molds to that flow. As I say it's a guess.
Tom Alves said:Oh well, it was only a guess. I'm still convinced burn in does exist but someone else will have to explain why
There are some people a bit closer to home that offer this service too, aren't there Tony?NeYank said:There are a number of high end companies that make cables, as well as hifi boutiques in the USA that offer a burn in service.
This service is not cheap.
I am not condoning it, but it exists.![]()
Imagine paying someone 50-100 quid just to burn in cables."
Burn-in is over and above the requirement to have the electronics at optimum operating temperature.Dev said:I'm not convinced about burning-in cables but in my experience HiFi does improve after a few hours of playing. The biggest change I noticed was with amps. I'm not sure whether this is burn-in or simply the amps reaching their optimum operating temp.
BlueMax said:Burn-in is over and above the requirement to have the electronics at optimum operating temperature.
Burning in can take hundreds of hours, unless special equipment (such as the one developed by Tony) is used.
