I guess the difference was not so big for me as the sorbothane feet made the first jump and then the oaknball make the next jump from there
good stuff!
Arrrrr tried two sorbothane feet at the rear and two oaknballs at the front, which I'd say was half a jump to the full 3 balls (no sorb).
I am actually finding on some tracks, the long bass notes are maybe a little boomy, I'll try the big chunks of pine under the speakers me thinks. Don't worry David not a side effect from your feet, a silver power cable opened up the pre amp wonderfully but showed up a slight weekness of bass control, I feel its the pre amp letting the side down a tad.
Here Pete, was it mdf, rubber and then a marble chopping board, that you sat on the DavidFeet with cdp on top ?
Like a rubber door mat..?
What did you find the composite platform did for you ?
(I'm hopefully treading carefully enough, as I did not get far in to your iso post, before it vanished)
