tones
compulsive cantater
What credence do you mean
To that, ol' spud, I have absolutely no answer
Everybody knows that an active device uses a small current to modulate a large one. It's obvious that this object uses the same principles. Think levers.0.3mW/m^3 is supposed to do something to the environment that has audible effect?
Tones said:t's quite heavy, and there is the sound of a smallish amount of light granular material (such as sand) moving inside when it's shaken.
New Age believers believe in strange individual electromagnetic fields, auras and whatnot. So, putting it all together, it seems to me that what we have here is New Age applied to hi-fi.
Or it's a blue LED in a box which rattles.
shame you heard no difference ...must have been much like when you tested one of my cables ......[that everybody else can hear except you]
just to be fair Pete, I tried them, and whilst being impressed by the excellent construction, and generosity of the trial, they sounded the same as the others I have.
I only mention because you said -everybody- and whilst I'm not especially important in the scheme of things, I'm a somebody.![]()
true .....!
must amend my memory ...[I've had 3 people say they can't hear a change]
actually it runs at about 2% of the hifi hobby that can't... in my experience
But again, you as I recall don't think cables make any difference either ....so a pattern could be developing.
No disrespected intended
Those hifi users who have found that their systems sound better by changing the wires they use, are strangely or not, often able to hear other "subtle" changes, in this I include mains cables, ic's, cd lathe etc.
Correct me if I'm wrong but all the dissenters are the very same people who Know none of the above work....[a generalization
of course] this is no great shock. Some of them would argue black was white if they thought there was any mileage in it! imo...
So tones still needs to explain why he has missed certain relavent parts from his long and well written post. Why would the dealer I contacted, stress the need to use the device in a virtually sealed room While the av dealer tones visited did not ? Its interesting that tones also wanted to show the other products available ...can't think why that was ...can you ! Would it be to add weight to his post .....if the unit tones used had no effect would this not be sufficient ?.....
As one of the effects I demonstrated to those people interested enough to listen to the unit in there own systems. Tones alludes to the use of a mobile phone. This is quite correct and acts exactly as described ...but is not so easy to accomplish in real life ....as Uncle ants will agree I had to try it several times before it was effective. A much better test was to just switch the unit off with the music playing and listen to the collapse of the sound stage ..most recently demoed to jimbo. In which case the loss of the effect was clearer than when the unit was first switched on in his opinion.
so we get down to the nitty gritty ....if I use a scale of 1-10 where 1 is no effect and 10 is mindbogglingly fantastic....
I've placed the zerogain members aganist the perceived effect..the numbers following are none zg member I visited...I can put there names up but that would be meaningless as your unlikely to know ...a mr woodcock of carlton, or a mr king of arnold etc [the asterisk is a pf member]
1......tones
2....
3....davidF
4....banpe2006 2
5....uncle ants 2
6....sq221759 ed rogerson* 4
7....Iainr, jimbo, jackotrades 3
8....zanash, tony.garner 1
9....1
10...
now I hear you shout you claimed 30 listeners [give or take].....the 13 none members had there wives or partners present and in a couple of instances so did the zg members.
[apology's to anyone I've missed]
This is meant to represent nothing more than a graphic illustration, no inferences should be drawn from this other than to show the level of perceived effect in various systems. Though it does look like a certain distribution curve ...but I'm not reading it as such !
So what am I saying ........all these people heard the unit in there own systems only five or so had specifically asked to hear it ..the others were offered a listen after we had in most case tried davidf's feet [now tones they really work and in some case make a bigger change than the room animator]
using the data above the percentage that have no effect is ....3% 1 in 30 ish that also correlates quite closely with the percentage at the top of the post. Could there be a reason for this ....who knows?
Though if you plough through some the cable flame wars, this does seem to be a fair percentage . I'm not going to say their right or wrong or attempt to convert them. If we accept that there are a certain small percentage that can't hear cables etc, and conversely a percentage [larger] that can, and no amount of tub thumping or demonstrations will be of the slightest use ...imo the happier we will all be.
I also did that, and nothing collapsed, not even my expectations (which, admittedly, were zero).A much better test was to just switch the unit off with the music playing and listen to the collapse of the sound stage ..most recently demoed to jimbo. In which case the loss of the effect was clearer than when the unit was first switched on in his opinion.
Naturally, your assessment was. As another poster previously statedI think you have answered everyones question with your final line...
I quote
says it all ....and shows this was not an impartial or valid assessment....imo
Here you go again. Please indicate to me when I haven't done this. I accept you hear what you heard. What I don't accept it that what you heard is actually there in reality.Why can't you accept that other people might just be able to hear things that you can't......
I'm happy that you can hear these things for whatever reason .....
Why can't you offer me the same courtesy ?
Eh? You're always saying, "use your ears". I do precisely that, and when I don't hear what you want my ears to hear, suddenly I have to take notice of other people's ears too. You are having me on, aren't you?I've never told you that what I'm hearing is correct [though I do know I am hearing it ].... it's backed up by all the other people I've mentioned and their posts, that you have ignored.
Aha, now it's the dealer's fault too...I can't second guess the conversation you had with the dealer ....maybe he's not up to much ? There are similar dealers in this country too ....who for what ever reason don't pass on all the information available ......
I didn't listen there. No point, because it would have been with equipment and music which I didn't know. Swiss dealers are generally happy to let you borrow stuff without a trial in the dealership, precisely because of that reason.I also note that no mention was made of listening in the dealership .....thats down right odd. I've only ever been offered a home loan following a dealer demo.....this case in point.
I went through the whole shebang several times. Although how exactly one reactivates something that wasn't active in the first place is somewhat of a mystery...Did you forget to mention the the reactivation process too ?
Yes, if it doesn't work, try again (that's what the (original German language) instructions say).If the unit doesn't work when you get it home ....there are some specific things you need to do ...I assume you followed these ?
Naturally - I told him I didn't believe a single word of it....did you happen to mention you knew the units would not work I bet you did ....?
He was a nice man, who obviously believes in the product he sells, and he was more than happy to take the risk that I wouldn't like it. He conceded that the price was high and that the difference perceived would have to be enormous to justify it. I naturally took the best of care of it, and now it's neatly wrapped in its original packing, ready to go back.If I'd been in his place I would have had to think very carefully if it was worth the risk of loaning the items to someone who would not be able to hear them.
Would you believe that this is the longest thread ever in the reviews sections? The second is the the CD Lathe thread.
Yes.... It's not getting anywhere the naysayers it can't work ...those who have heard it [except tones] all say it does ....
If the differences were that obvious we would not have this controversy.
Tones you have clearly missed a procedure ......if you don't know what it is please read the german instructions it clearly tells you to do something with the unit ....I'm not going to tell you what it is ......for the many obvious reasons. The unit requires activation the dealer should have told you ...but it does state this clearly in the fifth paragraph of the instruction sheet ....
ie you could just say ..yes I did that,
or what a load of rubbish or if it doesn't work out of the box why should I do anything else ...
... I did not incinerate it in the middle of a pentangle with a candle burning at each apex, and dance around it five times clockwise and then five times anticlockwise while reciting the appropriate verses from the Kabbala...
