brizonbiovizier said:Nonsense - I often listen at low level and I assessed the Kondo system in that context - there is no lack of broader experience muppet. I just favour different solutions to you. Horns will just make it worse. Tonal spray painting more like.![]()
sideshowbob said:Murray, you're forgetting that BBV has heard just about everything, he hangs around hifi shops a lot it seems. That's why he's a guru to so many on the forums, everyone respects his opinions. Also, you must remember that PMCs are better than anything else, and if you don't agree you're simply wrong, or the pair you heard weren't set up properly.
-- Ian
The Devil said:You have nothing remotely constructive to add, as usual.
The day the Clash goes on my system, whether I'm still listening to valves or not, it will utterly fall apart. I will take it all apart with a baseball bat if necessary to make the noise stop.brizonbiovizier said:Let's stick the clash on it and hear it utterly fall apart.![]()
Paul L said:The day the Clash goes on my system, whether I'm still listening to valves or not, it will utterly fall apart. I will take it all apart with a baseball bat if necessary to make the noise stop.
I know what you're getting at though. You want a system to re-create true dynamics.
brizonbiovizier said:If you dont listen to rock then any sme can be fine - even highly desirable. But for rock - forget it.
