bottleneck said:
''Neutral'' or ''truthful'' is a misnoma.
Better put, ''neutral'' is a lack of any extreme - e.g. detail retrieval or dynamics - and therefore as far AWAY from a live experience as it is TO the live experience...
..Live music containing extreme dynamics, detail, and power (etc)
You simply cannot have it all, and to pretend to do so is to be blind to the simple facts.
Pick a compromise that you enjoy.
Wouldn't you agree that is better to approach what's considered the the baseline for reproduction of sound - the recording. And rely on the recording to best try capture the venue?
I understand that's somewhat of loaded question with so many subjective opinions on how it should be done. Its just my opinion that you should narrow the variance between recording and the final measureable output of the system as a whole, including room. Its certainly accurate in terms of tracking the source and the onus is then the responsibility of the recording.
If you start voicing this and voicing that your dealing with not only imperfect recordings but also other more damaging distortions. Lessen the variables I say and it works very well for me.
I'm *not* saying this is the only way to get where you need to go but its certainly a very valid approach.
About dynamics: I think they come predominately from realistic SPL's. And system needs to play at those levels whilst still tracking the source accuratly. That makes sense because its only higher SPL's that have the neccessary headroom to give the range needed between peak and noisefloor to make us start to believe that the sound is proportional to what you'd expect in a traditional setting.
The word dynamics, when used in the context of discussing loudspeaker presention, is a description of several individual 'traits' that superimpose as a subjective whole. These 'traits' are measurable ie. its possible to engineer dynamics. It also has little to do with high efficiency.
Much of the 'dynamic' nature of a loudspeaker can be assessed by its impulse/step response. These are the absolute baseline performance indicators of just how accurate a loudspeaker is because they take into account both amplitude and time characteristics of the speaker. A lot of loudspeakers are poor in this regard and non are approaching perfect.
Since a loudspeaker is being asked to produce every possible eventuality for sound it must closely adhere to the fundamentals of how a perfect transducer would perform. Unfortunately no loudspeaker comes even close to that and will remain that way until we get a radically different approach to how we tackly the problem, in other words the technology so far isn't good enough.
