speaker cable
Status
Not open for further replies.
Hey S & M
These Zandenob inc cables. That wouldn't be a play on Zanesh and knob, by any chance?
Course not, S&M says he never posts nasty-ever, never ever and I believe him, then again I also believe the Nolan sisters all sleep under my stairs.
Good heavens no - I'm often referred to as his associate, or "ass" for short.
Chortle indeed.
Surely you've heard of the 5000 Signature?
OK men,
Our audio club has decided to perform a double blind test of ICs. Should prove interesting. Any suggestions for the test?
SM, any suggestions
David F, any suggestions
Your input is welcomed.
rollo
Let's say for argument's sake Zandenob inc. make a cable for £200 a meter.
Well, they also make a perfectly good £50 a metre cable on sale though selected agents. Indeed, there's a cable salesman selling it on this very forum.
well when i started my cable making journey, i grabbed some materials,madesomecables,listened to them,altered them,listened to them,altered them, etc etc and then finally stopped altering them.
maybe i could have made cables that sound identicalto what i now have slightly larger copper ribbon than the silver i used, who knows. i certainly don't care.
\Leffe brune.
http://www.sixmoons.com/audioreviews/synergistic/tesla.html
If you subtract the people making a buck out of selling cables from the poll I suspect the proportions will change markedly. They all come out of the woodwork when doubters voice their opinions and give the illusion of support for this specious concept. The silent majority simply doesn't care.
I second BBVs recommendation for plain old 79 strand.
Alternatively if you need a 4 core cable, Canare 4S11 is unbeatable being very robust (designed for stage use) and has low LCR.
A lot of cable for £3.50pm - I use it.
The manufacturer seems honest and gives plenty of technical info on their site which is a welcome change from some of unfounded nonsense posted about cables.
http://www.canare.com/index.cfm?objectid=ED7479EC-3048-7098-AF06286428706042
To quote Shakespeare......."hoist with his own petard"..
As a result of this thoughtful construction, Isolda Interconnect has a uniquely 'hear through' sound quality, devoid of the fuzziness, tonal imbalances and graininess which afflict other interconnect cables. But we've now found a way of making it even better.
As with the Enhancedâ„¢ Isolda Deep Cryogenic (EDCT) Loudspeaker Cable, the copper strip conductors are subject to deep cryogenic treatment and post-tempering prior to being assembled into the finished cable. The copper is slowly cooled to about ââ'¬â€œ190 degrees Celsius, held there for a number of hours, and then gradually returned to room temperature.
EDCT is proven to improve the lattice structure of copper, eliminating small 'dislocations', and has an amazing effect on the cable's final sound. Dynamics are improved, clarity is further enhanced and the sound takes on a difficult to describe but immediately recognisable naturalness that untreated cables cannot match.
OK men,
SM, any suggestions
rollo
Rollo,
I would have thought that it would be worthwhile having a bog standard cable (3 core mains lead?), a decent (but inexpensive) audio cable such as QED/Monster, an audiophile special (any Transparent/Cardas/Kimber cable), a super one if you can get one (you know knee tremblingly expensive) and then a left field cable (such as anti-cable). A fairly straightforward single blind test should work well (trying not to make it into a lab test). And then try it out.
It is unlikely you will convince the doubters (or the reverse if their is not any differences) but you will be doing your members a service/saving them money/sending them on the road to ruin depending on the outcome.
Will be interested in the outcome and promise not to bitch about it.
It's odd that George. I mean there's no discussion of those results anywhere that I can find. Which is bizarre. I can't find any sets of measurements for their audio cables though and I know they have a "reputation" in the industry.
The best source of cable measurements I can find is of course Audioholics, who have run a number of proper scientific cable tests over the years. Very interesting reading if you are worrying about cables and looking to save some money.
I agree. If I had looked after the experiments I would not have published those results, even the extended paper. They did not take proper account of other factors that could cause differences such as grounding issues. A pity as I would have liked to have quoted them to death to you.....:) Ho hum.....;)
I think Audioholics is somewhat biased and then proves its biases. Interesting reading but a bit closed minded. Some of the equipment they like sounds crap.
um, are you taking the piss?
Um no. I'm just pointing out that what ever his name is is barking up the wrong tree.
Cooky, when you see me spouting that BS and trying to get ZG'ers to buy the product, you can take the piss for all you are worth. Anyone making such claims deserves to be harranged until the cows come home IMHO.
That's the problem IMHO George. If you are biased but able to prove your biases, how can you be closed minded? If you prove something, surely you are simply correct? I take your point though - a lot of audiophiles would take issue with their stance despite it's provability and grounding in solid well researched science. I think we seem to have the same problem here :D
SM, Did you start with the bog standard Isolda's and then after selling a few pairs make enough money to upgrade to the cryo'd version or did you jump straight in and opt for for the super dooper sounding improved version from the start??
Everything about the IC can make a difference. The conductors specs, the connectors, the winding, solder,dielectric. The LCR matters as that is what you need to know to synergize the cable with your system. Its a good thing to know and would probably narrow the chase. IMO we need more published specs from manfs to make the choice easier. However in the end, if it dosn't sound right the chase continues for me at least.
rollo
OK but people keep quoting LCR parameters which is only half the argument. These differences then need plugging into the right equations and the impacts calculated. If you do that using 'conventional theory' you will find that the majority of cables may measure subtly different (especially with 'super digital measuring equipment') but their impact on things like frequency response is really miniscule. So LCR parameter differences do not relate to cable differences for the majority of cables.
But even this is a sop.
All published DBTs (that I am aware of) have not shown statistically significant differences between cables. So LCR parameters may change, frequency response (as an example) may alter but no tests have shown people can hear it.
QED?????????????
I know I prefer Pepsi to Coke but in a DBT couldn't tell them apart after about 5 goes:)
QED?????????????
Would you care to explain that George? If any differences are not measurable via the LCR characteristics, what do you put them down to?
The argument is AFAIK, that you can have small measurable differences that will not be audible, but you cannot have audible differences that will not be measurable.
Status
