hi steve,
i have just briskly run through this thread and what i will add has been totally over looked by those idiots on there, one of the main reasons why most transistor amps have that paticular "grainy" sound is because unlike valve amplifier circuitry that produces mainly low order harmonic distortion ie, usualy no higher than 2nd and 3rd order, most transistor amplifier circuitry produces low and high order odd harmonic distortion,ie, 3rd 5th 7th 9th and so on, and its the high order ODD harmonic distortion that we cant stand listening too for any length of time, in even very small amounts! this is one of the reasons transistor amplifier manufactureres try to get their over-all distortion ratings as low as they posibly can , its to try and eliminate even the smallest amount of these high order harmonics!!! also sometimes
when you put a valve circuit after a solid state circuit that is producing these high order harmonics, the valve [remember not being able to produce high order harmonics] will supress those high order harmonics and therefore can make the previous un-listenable circuitry sound well,,, listenable!therefore, valves have natural compresion and limiting characteristics, which give them the ability to re-produce sound in a way much closer to what we recognise in real life!
i am not a member of that forum so i cannot comment direct, but you can by all-means quote what i have written, it may help, but reading between the lines with some of these characters, i doubt it.
regards,anthony,TD...
