Astonishing comment about something you've never heard.
Lot of that about though in audio land.
I've heard enough of behringer though... I've been passed quite a few bits of theirs to play with when I was into writing music.
If you want to do a test , how about this :-
Get a CDP , record the output into a CDRW take the CDRW and then play it in the CDP and record the output ... do this 10 times with each different cable and see if there is difference.
Although the continuous ADC/DAC stages will degrade the sound , in theory (if cables do actually sound the same) the end results will turn out identical. Any differences between them will be highlighted 10 fold and will be much easier to hear and less dependant on the quality of your ADC conversion.
As an example , if cable "A" reduces the bass by .5db then by the time you have done it 10 times , the bass would be reduced by 5db and will be easy to spot. You wouldn't need to even use music , get a white noise blast for 20 seconds or so as that would be sufficiant.
ofcourse , this all sounds like amazing fun , but I'm thinking you could do it when the group of you all meet up for a fun day of cable swapsies
