Another pointless Mana debate
analoguekid said:
Yeah Paul, but for the retail cost, some £36,000, some of us expect a lot more,
But isn't it JW's old system :confused:
Have to ask why, if it really was that good, Mr Watson was happy to sell it on don't you.
Well I know the speakers are, and possibly the TT, not sure about hte rest of it, JW could have given it to Bub, and still made money, the amount of endorsements it has generated.
Guru's eh, Santana had Sri Chinmoy, Neil Peart had Ayn Rand, James has JW
Yes Merlin. It's actually not really all that good, but we had you going, eh?
Googled it :-
Reverberation Time
This is the time it takes for an initial sound to decay in volume to a certain level. The technical definition of RT-60 or reverberation time is the time it takes a sound to decay 60dB or shrink to 1,000,000th of its initial impact or sound pressure level. RT-30 and RT-90 measurements are also used, albeit less frequently. It is important to preface this discussion by stating that reverberation time measurements were developed for large venues such as concert halls and churches. These venues have large and diffuse sound fields in the audience sitting areas. It is these diffuse sound fields that make up the context for critical RT-60 measurements.
Most of the time the answer is quite simple: pile up the cabs and make it so bloody loud (just avoiding feedback, by whatever means necessary) you can't hear a damn thing anyway.
Works for us...
fox said:
I'm wondering how relevant this measurement (as Andy has pointed out is usually quoted for large spaces like cathedrals) is for an enclosed space used once for recording?
:eek: how big is Bub's pad and what's "The Devil" doing in a Cathedral ?
I don't need any help, Merlin. It's unfortunate that you are so far away. If you came over for a listen, I'm sure that you would understand what we are talking about.
FWIW, I've done a room sweep with a test tone CD that was left here one time. All seemed benign.
Hi AK,
thought this would be a good time/place to join; its about as much use as most of the threads to which I contribute on any forums. :D
