Saab said:Antonio
how does big torque help with cornering on a bike?
merlin said:Thinking of LOTR, I can't help casting WM as the little Dwarf chappie![]()
merlin said:Talking of middle aged t*ssers on Motorbikes - g'dmorn Antonio![]()
lowrider said:It sure helps getting out of it faster, if you ride street racers you know that in a twisty road you need to constantly change gears to keep the engine in the good torque rpm, otherwise you have no power to pull out of the corners, I think it is quite obvious that if you are busy with the gear lever it will be harder to corner properly...
Believe me, it is quite obvious on the road...
No wonder the standard of literacy in this country is so lowlordsummit said:What really bother's me...
Saab said:brake.........change gear........turn in on the throttle
ist easy really![]()
Lord,lordsummit said:I would particularly like to cite WM for being especially difficult, a crystalmark for clear English is unlikely to be heading his way.
Arse
wadia-miester said:If ever there was a case of mutton dressed as lamb Antonio, that has surely got to be it![]()
