Dev
So Chris, are you saying that if we buy an appropriate transport, we can forget about all these "tweaks" and just enjoy the standard CDs?
Agree that that effect exists - but in my case I just listened to a CD that had been lathed for me, and had no intention of buying a lathe, so had no financial motivation, just curiosity... The pair of CDs I used had previously been used to test for differences from other tweaks - freezing, reveel, relees, wacko cosmic foil - and I heard no difference from any of those. I know my player (as was my old Krell) is sensitive to irregularities in the centering of CDs (I have some old Decca ones which run a bit clattery because of that), so it could be that the lathing has corrected that in some way - even though that's not supposed to be how it is generating its effect.sideshowbob said:I think I can shed light on the mystery.
If you have spent £300 or so on a device to lathe your CDs you WILL hear a big difference.
If you have not spent £300 or so on a device to lathe your CDs you PROBABLY WON'T hear a difference, big or otherwise.
Conclusion: there isn't really a difference at all, unless you really want to hear one.
-- Ian
bottleneck said:not really..
it seems more like....
1) it is CLEAR to hear what the CD Lathe does if you have a Meridian 500 Mk2 transport..
Also..
2) It is CLEAR that the CD Lathe doesn't do much if you have a Meridian 500 Mk2 transport..
-- Ian
Also..
-- Ian
zanash said:Its interesting to note that bottleneck found no difference ...did you find the same with some of your other comparisons recently ?
STELLABAGPUSS said:Anyway it's certainly a million miles away in terms of preformance of the bog standard 500 Mk2 transport which I started with.
bottleneck said:hiya
Yes, my Meridian 500 has been most extensively modified.
I've used clock 10 on the transport, EMF'd the upper body of the casing.
Capacitors have been replaced with neodymium field coils, and bybees at every junction.
Stilton points are used under the corner points for added virtuosity, and this really clears up the muddle in the middle.
The power cable has been replaced by shunyata tree trunk. The extra detail is impressive. Unfortunately the cable doesn't bend so I've had to build a magnetically levitating tower to balance the transport on top.
All in all there has been a 62.5% improvement in ALL areas.
